Earth Fault Loop High ? | Page 2 | on ElectriciansForums
Discuss Earth Fault Loop High ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thats more like it thanks spinlondon for your greatly appreciated input
cheers
Acestu
Special locations ,stables are Part of agricultural buildings and special locations section 705 of the regs ,and the reason is horses can be classed as live stock its an animal so it is required to be protected against electric shock and burns etc also stables contain flammable and combustable materials IE straw and hay , also the cleaning methods in stables are water jets so it will then require accessories to be IP rated to IPX5 , cabling should be protected against damage which in general terms will be SWA as steel conduit rusts , as for a question the swa although you can use the armour as an earth, but it would be far more benificial to use a cable with an incorperated earth as some sizes you will require an additional earth
the argicultural buildings debate it doesnt matter what planners class as agricultural its what the BRB defines and the definitions are clearly set out in it
They are NOT Tester Sockets Amp David they are Socket Testers, maybe they are no good for Dyslexic sparks
Merry Xmas
Acestu
and certainly not for me witrh dyslexia and altzeimers. i would forget where to plug ........ sorry, what was the question?
Nice 1 Tel, you cant beat a bit of humour at christmas, plenty of clowns on here to interact with who dont understand it....
Merry Xmas m8
Acestu
P.S. I couldn't see your post at first, i am colourblind and only have 1 eye,, sorry
Reply to Earth Fault Loop High ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Very informative and helpful. I would have thought that the real intended purpose was to make money.
Good thinking - the other side of that is my garage and also where the gas comes in so probably quite a tidy solution if it comes to it!
