Earth rod | Page 3 | on ElectriciansForums
Discuss Earth rod in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
3 months ago I sunk in 3 rods, two were 4m deep and the other 3m deep, Ra achieved at the time was 3.1 ohms using a Three lead spike test kit.
i hooked the summerhouse up today and finished it off,
i measured Ra again and it was 2.5 ohms, then just to let you know how close it was to Ze, so accuracy of the spike test, Zdb at the new board came out at 2.88 ohms, that was on the end of a 52m run of 16mm SWA.
im very happy with the end result.
[ElectriciansForums.net] Earth rod[ElectriciansForums.net] Earth rod[ElectriciansForums.net] Earth rod
That did follow with not always glue them but often I do. To be honest glueing them just makes life difficult for you when you want to change the setup a bit.
Again, seriously?
What the hell is going to stop the whole lot falling apart if you don't glue it? It's an obvious failure to correctly erect the wiring system so a basic failure to comply with the regulations.
Again, seriously?
seriously how will it fall apart if you dont glue it?
i wouldnt think the conduit would shrink more than 20mm between boxes?
Expansion and contraction will depend on how much the temperature changes and what temperature the conduit was at when it was installed.
There are other things which can cause it to fall apart. Natural movement of the structure it is fixed to or bumps and knocks can cause it.
fair enough, normally i would prefer black steel conduit rather than plastic if i needed to install it outside
Reply to Earth rod in the UK Electrical Forum area at ElectriciansForums.net
