Discuss Earthing System in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's not likely to be TT at 0.19 Ohms (never seen that low a value). If the L-N impedance is higher than Ze then I'm voting with Karin and Spary for TNCS. Is there a prize for the correct answer ?True it could be TNCS...
Unfortunately I won't be able to find out where the other end goes..
Ze reading is 0.19 Ohms, isn't very low as for tt system?
Reply to Earthing System in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
