EICR Code for no main earth | Page 5 | on ElectriciansForums
Discuss EICR Code for no main earth in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I can't knock you there because at the end of the day it's the inspector who decides what he thinks the code should be and he alone on his engineering assessment codes it, no-one else!. However all guidance on the matter to help the inspector decide points towards it being a C2 ....
You're right!
That's it! From now on, no 30mA RCD for additional protection gets a C1 from me!
You're right!
True to an extent but this is clear cut c2
The easiest way to define between c1 and c2 to is basically can this situation cause harm right now exactly how it is.
No earth can't, it just has the potential to under fault conditions
So C2
Can you get a shock from it all else being well with the installation?
No?
Then it's not immediately dangerous is it!!!
I can't help playing devils advocate on this one.
Given the earth is functional as well as protective if the main earth is missing I'd say it would be reasonable to expect touch voltages of CPC to rise as electronic appliances are connected or even if there's an everyday surge or spike that causes surge arrestors to conduct. Neither of these events would be classed as faults so I could see the case for declaring it an immediate danger therefore I could see the case for declaring it a C1 issue.
Thats the beauty of an EICR, you as the inspector decides what you think the code should be based on your engineering assessment of the situation! If you live in a high 'surge' area, or have lots of electronics attached, or anything else that may introduce voltage onto the 'earth' then you may well declare it a C1 -- thats your engineering judgement!
If nothing of the sort exists then as a general rule C2 is recommended.
I think it 's not just 5WWs doing stuff like this - there are other factors. Firstly, as everyone knows , an eicr can bring in more work! There is still, and it's more prevalent in more technical trades, a (rightful!) distrust of sparks because people can make stuff up to get remedial work. Not sure how you can get round this one!!??
Secondly, there is a lot of hearsay - ppl taking stuff as read without thinking about it or looking at BGB. Eg - 12v light fittings/fans in bathrooms etc etc etc. I know I have been guilty of this but I am learning and am humble enough to be corrected.
But...solid education basis can definitely steer the 2nd kind of person - if it is drilled into them to question everything and how to use regs book well that helps too!
As for the cheating cowboys, I like to think that those blokes will never truly be successful and society and economics has a way of sorting wheat from chaff and honest from dishonest.
The only thing that can buck the trend is ÂŁmillions spent on advertising, PR and marketing in the name of looking after people's world.
PREACH IT
Reply to EICR Code for no main earth in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Personally, I would just put them in the observations, the inspection schedule is not exhaustive.
So it's OK to use a backbox with isolated lugs - even though the switch and the wiring in the box won't meet the standards for Class II. Plus the...
