EICR - Do these C2's Sound Legit? | Page 2 | on ElectriciansForums
Discuss EICR - Do these C2's Sound Legit? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I understand RCD protection, what makes no sense is your statement that it is a common denominator in relation to getting multiple quotes??
Ah right my bad I get you, I said get a few quotes so you can judge the best. Common denominator was my way of saying that it will be get rcd protection. In other words they will all say you need rcd protection so that will be the common denominator. Does that make sense Dave?
Reply to EICR - Do these C2's Sound Legit? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Definitely, although most likely within the accessories. I've often found that once accessories are disconnected the cabling IR is fine. Sometimes...
