EICR On small industrial unit | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss EICR On small industrial unit in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
A friend of mine owns a small unit, i have the papers from when it was last tested 10 years ago and also 15 years ago, but a lot of its been pulled out since then.
Ill be honest, I do not generally do periodics on this type of building and would like a bit of guidance.
I know how to test the circuits etc, its not that, thats the issue, its more with the BS number and what other peoples thoughts are for the setup where the board is really.
Take a look at the photos and see what you think, its a courier business and they wash vans out the front and take extensions out, nothing is RCD protected, generally the condition looks ok having walked round it yesterday.
[ElectriciansForums.net] EICR On small industrial unit[ElectriciansForums.net] EICR On small industrial unit[ElectriciansForums.net] EICR On small industrial unit[ElectriciansForums.net] EICR On small industrial unit
BS EN 60898 'low voltage circuit breakers for use in household and similar applications'
BS EN 60947-2 'low voltage circuit breakers for use in industrial and similar installations'
So it all depends on how you define 'similar installations' , I think small commercial offices/shops would be, but what else?
in this paticular case bs60898 breakers are adequite because of the enviroment conditions and measured test results (its located in a school)
Cheers for that Dave. First time I have heard 60898 referred to as "household" , that's what confused me.
I found this download for some informative bedtime reading ...
http://www.beama.org.uk/download.cfm/docid/6BCA1329-8A17-4C89-B86A629F18D74BB8
You're lucky, all the school/commercial boiler rooms I get to work in around here are grotty horrible places, damp and stinking of oil. You'd assume the higher pollution rating to be specified for them.
nah the worst plant room ive worked in was city hospital in birmingham.
national grid officess plantrooms are defiantly the cleanest ive been to.
the breakers are usuallu dual standard but usually the older plant we work on is bs88 fuses
Reply to EICR On small industrial unit in the UK Electrical Forum area at ElectriciansForums.net
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
Hello Dave, Thanks for taking the time to reply. I appreciate the info, I haven't updated this post yet, but I have since been talking to some...
Recommended Sponsor News
Hi everyone,
