EICR or Minor Works??? | Page 3 | on ElectriciansForums
Discuss EICR or Minor Works??? in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Just a quick one.. I have been to a job today where the shower isolator switch had burnt out, as it wasn't RCD protected I replaced the switch with a 1 way consumer unit with an RCD.
My question is..do I need to do a full EIC or would a minor works do?
Cheers
Why did you not fit an RCD in an enclosure the circuit should already have a protective device at the circuit origin so from that perspective I can see why members are saying EIC as a new circuit. I assume this existing burnt out switch was either outside the bathroom or in an adj cupboard. I agree with Pete on what is wrong with adding an RCD to increase the level of safety. It's MW but there would be nothing wrong with issuing an EIC just more paperwork.
Reply to EICR or Minor Works??? in the UK Electrical Forum area at ElectriciansForums.net
For a new circuit or alteration the dead tests should be done first to ensure it is safe to energise.
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
