EICR or Minor Works??? | Page 4 | on ElectriciansForums
Discuss EICR or Minor Works??? in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Just a quick one.. I have been to a job today where the shower isolator switch had burnt out, as it wasn't RCD protected I replaced the switch with a 1 way consumer unit with an RCD.
My question is..do I need to do a full EIC or would a minor works do?
Cheers
You haven't wired a new circuit, you have altered an existing circuit MNW
I could kind of see where ESSEX was sort of coming from as switchgear rather than an accessory a subdistribution circuit has been made hence why saying EIC if an RCD in an enclosure replaced the isolation switch it would have been a straight MW.Still agree though can be MW for what's done.
Reply to EICR or Minor Works??? in the UK Electrical Forum area at ElectriciansForums.net
For a new circuit or alteration the dead tests should be done first to ensure it is safe to energise.
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
