EICR - PLASTIC CONSUMER UNIT CODE C2 or C3 | on ElectriciansForums
Discuss EICR - PLASTIC CONSUMER UNIT CODE C2 or C3 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
west sussex
After your thoughts on EICR coding for an existing plastic consumer unit in an under stairs cupboard, firstly in a standard domestic dwelling and secondly in a house of multiple occupancy.
After discussing this others and with tech helplines seems to be a bit of a split as to what code!
An insulated consumer unit in good condition is never ever a C2. Anyone who codes it as such is a chancer IMO.
I generally don't code them unless they are in an understairs cupboard. Begrudgingly I would normally the code it C3 in line with guidance
Is this an EICR you are doing or one that has been passed to you. If the former then may be you should consider that after discussing it with others, using tech helpline and now a forum you should find another aspect of your trade.
And your thoughts on this? That was all I was asking for!
What guidance.
Why is that funny Westward 10 ?
It just is, I have visions of all these incompetent people carrying out Periodics whilst at the same time flicking through a Guide telling them how to do it. Imagine being at the dentist for a root canal and they have the Best Practice Guide for root canal methods propped up on the side.
The people that write this guide should be allowed to write BS 7671 as its to the point and includes decent examples.
I suggest end users read it .....
All you are saying with a C3 is that a significant improvement to safety can be acheived by in this case making the surrounds or consumer unit fireproof. Personally I feel if it is under a stairs an important escape route could be compromised if a fire started under it. I don't know about you but I would not be happy with that potential risk in my home especially with kids about, being serious for a moment!
Reply to EICR - PLASTIC CONSUMER UNIT CODE C2 or C3 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That is what i am going to do. Thanks mate!
