EICR - PLASTIC CONSUMER UNIT CODE C2 or C3
Best practice guide No 4
What does it say in the Best Practice Guide No 4 about plastic CU's?
Are we not working to BS7671?
I can't find anywhere in BS7671 that states we should refer to Best Practice Guides.
As stated above, there are thousands of plastic CU's. To code them for just being plastic is wrong IMO.
If you are going to code plastic CU's then you have to code surface mounted cables that don't have adequate support against a fire.
It just is, I have visions of all these incompetent people carrying out Periodics whilst at the same time flicking through a Guide telling them how to do it. Imagine being at the dentist for a root canal and they have the Best Practice Guide for root canal methods propped up on the side.
Mr Westward10,
I had a discussion with some friends (all experienced electricians) on this and there were different views. So we called 2 different tech lines to ask theirs, again there were different views. So thought that I would register again (after about 5 years away) with The Electricians Forum just to see what other tradesmen views were. Just to start a discussion!
So I just wondered what your opinion actually was and maybe why?
The guide recommends C3 in individual dwellings and C2 in communal areas of larger shared dwellings for this issue.
This guide is contributed to and endorsed by the IET and BSI among others.
OK, if people are coding these things then come January I presume you will be coding any circuit that doesn't have an AFDD fitted to it?
BS 7671 AMD 3 does nothing to clear up the farce of metal CUs
My first response on this thread offers up my thoughts
An insulated consumer unit in good condition is never ever a C2. Anyone who codes it as such is a chancer IMO.
I generally don't code them unless they are in an understairs cupboard. Begrudgingly I would normally the code it C3 in line with guidance
This post is a complete contradiction.
These Guides can lead to narrow minded thinking as opposed to using your knowledge to judge each scenario on its own merits.
I agree with that train of thought. I think the reasoning behind the guide is an attempt to standardise coding of common issues what with any bugger let loose on inspections these days.
I fully agree that each situation is a unique judgement call as to the perceived hazard or danger though.
Which I would do.
All you are saying with a C3 is that a significant improvement to safety can be acheived by in this case making the surrounds or consumer unit fireproof. Personally I feel if it is under a stairs an important escape route could be compromised if a fire started under it. I don't know about you but I would not be happy with that potential risk in my home especially with kids about, being serious for a moment!
Whilst the inclusion of metal boards has reduced fire risk (for whatever the actual reason plastics suddenly became a risk)
The number of incidents of molten dist boards (when installed correctly) must be minuscule,the potential risk would reflect that
Life is full of risk,its good to reduce that risk but lets not go over the top:eek:
If the board is installed correctly and/or correctly inspected, the risk is likely to be as low as its ever going to be compared to a new one even if it were made from asbestos :rolleyes:
My view on this as you are giving someone a professional opinion on their installation as of the date of inspection. I would therefore give a C3 whatever the location. A metal consumer unit would now be fitted if this was a new build property and therefore an improvement could be made/recommended. Should there be a fire within the CU/house at a later date and it was not contained and caused damage or serious injury or death the owner/householder/insurer/courts could state that you did not draw to their attention that this was an area where improvement could have been made to their installation. Cables in escape routes are not normally visible so would surely be a lim. An old boss of mine always used to say to me, when you make a decision you should firstly consider what it would read like on the front page of the Sun or when reported in the local news when it all goes horribly wrong!
