Electrical installation certificat | Page 4 | on ElectriciansForums
Discuss Electrical installation certificat in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I dont mind a berating when needed but ive been battered by the old guard i do wish i never asked for advice .
You have learnt a valuable lesson on here. If you show your competent but you need advice they warm to you but they won't wipe your backside for you.
Too many mistake words during your posts M8, come on own up now, you are not a 15 year experienced electrician are you?
I am aware my knowledge of testing is very short and as you say im still learning myself after 15 years thanks for your comment.
Fair enough, good luck with the domestic route then, with 15 years experience you should be very well clued up and should take to it like a duck to water.
Now thats not very PC , he could just be dyslexic and colour blind like me !:jester:
Joking apart , i would never knock a man for bad spelling . I know at least 3 self made millionaires that can hardly read or write !
I qualified in 1997 236pt 1/2 nvq level 3 pat test qualification know part P ive done site maintenance work done work on perssimon homes on new build worked on offices blocks hospitals and just decided to go back in to domestic.
Ok, so I'll take your word for it for a moment. Just answer me one question would you?
You have a 10kW balanced three phase inductive load. L1 is drawing 16A and is being supplied by a conductor with a 2.5mm csa. L2 and L3 are 4mm conductors. Calculate the size that the neutral conductor would need to be in order to ensure that it has an adequate current carrying capacity.
This should be a very easy and straight forward calculation.
PLEASE ONLY LET THE OP ANSWER THIS!
Reply to Electrical installation certificat in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
