Electrical oven installation | Page 3 | on ElectriciansForums
Discuss Electrical oven installation in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Just purchased a new oven which has a 13amp fused plug attached. The kitchen has a cooker terminal which has 6mm cable coming from it. The existing oven has a 2.5mm flex (no plug). The hob is separate and also has a 2.5mm flex. Both oven and hob have been chocolate boxed to the 6mm cable - I did not do this!
So I want to be able to plug my new oven in and use the existing hob. The hob specs are 250v and 6kw - mania says to use 2.5m cable which is what the previous owner of the house has done. The new oven is less than 3kw.
Is it ok and proper to place a double gang 13amp fused socket on the end of the 6mm cable which comes from the terminal. Then fix a 13amp plug to the hob - attach the socket to the wall and have both oven and hob plugged in. This preserves the existing terminal in case the hob breaks and we need to hard wire one in the future. Is this ok to do?
[ElectriciansForums.net] Electrical oven installation
That’s a bit of a myth I’m afraid . If in doubt email the manufacturer. I found that most are not bothered. I did read somewhere , that moulded plugs are used to simplify the manufacturing processes and has nothing to do with safety.
Absolutely. more words here and here
Essentially the safety aspect with a moulded plug is that it prevents an Ordinary Person from attempting to fit a wired plugtop and getting it wrong, be that be miswiring, not sufficiently tightening, leaving exposed or nicked inner cores, etc, etc.
Reply to Electrical oven installation in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
