Personally I think its easier to explain what you've done to each circuit on MW certsWhy? Not saying either is right or wrong just wondering why?
Discuss Electrical sigh off in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Makes perfect sense mateRegarding certification. For example trev If you worked on 5 circuits in one propertyno new circuits added you wouldn't issue 5 minor works certs you would issue 1 eicr for them5 circuits. well I would as I wouldn't even consider 5 minor works. I don't really think it matters either way.
Obviously not as you would testing the whole house so you might as well use the EIC cert.So if you changed every accessory in a house all 10 circuits you would go as far as 10 or is 5 your limit
Well returning to the OP, I have been in contact with the builder today and he has said that the electrical work will be part p certificated on completion - presumably by this guys mate who is a spark.
However I have to admit that I am still a little unclear as to whether I need a MWEIC or EIC?
For all I know this guys mate might be 'dodgy' As I stated previously I need to ensure that safety is paramount and everything is done properly.
Are there any particular questions I should be asking the builder / his spark?
Simon
Part P is "self certification" so if the builder wheels in a sparky at the very end you've not seen before then the alarm bells should ring.
New circuits = EIC
Modification to circuits = Minor Works Certificate
Get the scheme name and number of the sparky and don't pay for the electrics till you have the certificate(s)
That's exactly what the builder is planning to do!
What is the purpose of having the scheme name and number if he has provided me with the certificate (assuming this happens).
Does anyone think that I should get a second opinion though evening if the guy provides the required cert as safety is of paramount importance.
Simon
To make sure he is actually with a scheme at all. I know you have been promised part P notification, but once you have paid up..... ? And also you can contact his scheme and ask if they think the way things are being carried out on your job is suitable to them.
Simon
Because anyone can buy certificates. You need the scheme and number to check him/her out.
Google competentperson
the problem is that any spark coming in to certify the work will not be able to ensure that hidden cables are correctly installed. by completing an installation cert. the guy is taking responsibility for the work of others. the best way forward is for him to use a 3 signature certificate, whereby the original installer signs for design and installation, and your registered scam member sparks signs for inspection & test.
Reply to Electrical sigh off in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
