Emergenct Stop Switch wiring | Page 3 | on ElectriciansForums
Discuss Emergenct Stop Switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Why would you put a pump on a plug, some irriot will unplug it!!
Are you an electrician? If you are why are you asking such a question, if your not, pick up a phone book and call one as you clearly do not know what your doing regardless...putting in an E-Stop has to be the easiest thing in the world FFS!!
How about you stop beating around the bush and tell the guy straight :)
Got back about 1-ish .. the beer just kept flowing :17: and didn't I know it today :death:
Did you win tho?
Can see it now................Outspoken was the quiz master and first question.....................
Q.....How do you fit an e-stop onto a pump plug?
Surprised you got away at 1am to be honest lmao :)
Did you win tho?
Allan, please explain why I would ask such a damn fool question...It would more likely be;
"Why would you fit a pump with a BS1363 Plug and then attempt to fit it with an E-Stop"
Now that is an answer i would like :D
My point exactly lol
You didn't make the questions up mate you were just asking them:)
Did you win tho?
didn't win but apparently the beer pump refuses to stop flowing so Im considering fitting an E-Stop to it....
Reply to Emergenct Stop Switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Even if it’s says that the neutral is bonded to the generator, you still are required to install a ground wire from the generator to the transfer...
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
