OP
tazz
Dont forget to put a sign on it....£50 for inproper use....!!!
Discuss Emergenct Stop Switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Allan, please explain why I would ask such a damn fool question...It would more likely be;
"Why would you fit a pump with a BS1363 Plug and then attempt to fit it with an E-Stop"
Now that is an answer i would like
I thought the OP wanted to connect it across two phases !
As the pump is on a 3 pin plug it suggests it is single phase (although it could be 3p with no earth!) but the isolator you have pictured is clearly for three phase.just cut the cable. a separate action of applying choc block and tape is required to restart the motor, so it's safe. cable cutters shown below, take your pick:
Are you really serious, either your taking the **** or the Guy was not a qualified spark from even the most backward nation. If it is running on a standard plug how the **** would it be dual phase, you only have a LIVE and a NEUTRAL as it is SINGLE PHASE...either that or you have rewritten the laws of physics!!
Fing Magic
Time to get yourself a copy of 60204 and have a good read mate
The last post was nearly 3 months ago mate (5th May). I hope he has sorted it by now.
What’s the film? An adaptation of War and Peace?
Pride and Prejudice lol.
Reply to Emergenct Stop Switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
