OP
daiplayer
Meter tails will not be extended ( wouldn do tha) ...they will be shortened, ( brought closer to main income )
Discuss Entending cables for new cu in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Crimping of earthing cables is fine.
i didnt mean extened meter tails, i meant how long will they be from cutout to cu if you are moving it 5 metres??Meter tails will not be extended ( wouldn do tha) ...they will be shortened, ( brought closer to main income )
Regulation 543.3.3 concerns connections and joints being accessible for inspection in protective conductors.
There is no regulations at all mentioning joints or not having joints in section 544 for bonding conductors.
I agree it is good practice to have a continuous conductor for bonding/earthing but sometimes that is not possible.
i take it you are aware of recommended max lengths for tails??
Do you know what Malc, after i posted that i remembered that there used to be something in the yellow OSG that stated bonding conductors must be continuous through out their length (or something like that). When bs7671 2008 came out, this was no longer the case as i could not find it anywhere.
Still, crimp every time for me.
Jas don't the GN 8 still have something on continuous conductors for bonding/earthing, I've not got mine out here so can't look it up.
DNO normally stipulates 3M max from cutout fuse.the old installation is aprrox 3 meters beyond front door ( main cut out is located outside.....in cabinet....next to front door).
When moved ....it will be brought above the front door , and therefore tails will bne shortened ....not extended
Max legnth for tails.....please advise for future reference . MANY THANKS
supplier normally advises max length, usually 3 metres.the old installation is aprrox 3 meters beyond front door ( main cut out is located outside.....in cabinet....next to front door).
Just sat ...and passed the 2391 visual inspection practical assesment.....i was reqiured to find 14 visual electrical faults with a mock up installation......the bonding not being continious was one of them .....
If it helps at all ?
Reply to Entending cables for new cu in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
