EV Charger Installation - Cabling Query? | Page 10 | on ElectriciansForums
Discuss EV Charger Installation - Cabling Query? in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Give it 12 months this isnt going to be an issue as the new generation of chargers such as the podpoint solo are now coming out which can be used on a PME supply with no rod required. uses a mix of DC monitoring and a mains tails clamp to assess loads etc..
Don’t need to wait 12 months, the new Zappi already handles it on pme..
Hi,
We had a EV charger installed recently over the past day ie 32amp 7.2kw. In the fuse cupboard I’ve attached before and after photos.
I have a 100amp fuse for the house.
For the new EV board setup, should the 2 grey cables entering the EV board (10mm) be the same 25mm thickness as the other cables?
Would this cause any issues for me? Or is this against certain electrical standards?
Someone mentioned to me if I was to change the meter or DNO were to action any new improvements, that I’d have to get these 10mm cables changed before any work would be carried out in the future?
I have yet to settle on the work, so if there’s non standard work complete here due to this, I would be in a position to highlight and query the relevant electrical company. I would appreciate any advise?
Please excuse, as my knowledge in electrical stuff is non existent. It maybe that all is looks fine, and I’ve been given wrong advise.
Regards,
HY
Why is two earth cables going straight to charger? The other one should be going to your MET in the fuse board!
Hi,
Regards,
HY
Why is both earth cables going into your ev charger? The other should be going to your Wylex consumer unit!!
I think one earth does go to the Wylex board - behind the tails.
Mind you it was 4 years ago so let's hope so!
Reply to EV Charger Installation - Cabling Query? in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
A day for sure. I recently installed an Anderson with dedicated CU. The run was a fair bit worse as I had to drop a section of ceiling and chop...
They won't do groundworks but you can get a quote from them for an EV charger install. https://octopus.energy/get-an-ev-charger/
6K
