Exam question help | Page 3 | on ElectriciansForums
Discuss Exam question help in the UK Electrical Forum area at ElectriciansForums.net
P
PeterPan27
Hi all just done this **** exam and these are the questions a rememberd and wrote down in notes,,
re: Exam question help
The non stat document that is applicable to the construction and use of test equipment is?
a- bs7671
b- gn3
c - gs 38
d - osg
When a number of additional circuits are connected to a distribtion board the overall resistance will?
a- Decrease
b- remain unchanged
c- be a average of circuit value
d- increase
Which one of the following devices is suitable for PFC in excess of 60kA?
a-bs 88-2
b-bs 3036
c- bs 1362
d- bs en 60898
Where no supply is availble, a test of earth electrode resistance for a installation forming part of a TT system can be carried out using?
a-Earh fault loop impedance teste
b-a continuity tester
c- An earth electrode teste
d- a low resistance ohm metre
The earth fault loop impedance of a radial circuit must be measured at?
a-the origin of the circuit
b-any convenient part of the circuit
c-the furthest part of the circuit
d-every switch on the circuit
a- bs7671
b- gn3
c - gs 38
d - osg
a- Decrease
b- remain unchanged
d- increase
This question is usually for insulation resistance and not resistance. Reckon its a typo :86:
a-bs 88-2
b-bs 3036
c- bs 1362
d- bs en 60898
a-Earh fault loop impedance tester
Think about it Peter, to use an EFLI tester you need a supply voltage, the question is telling you this isn't available:o_O:
Its asking to measure EFLI for the radial circuit, not the supply so its wrong :o_O:
Mine in green
My try
here we go
a- bs7671
b- gn3
c - gs 38
d - osg
a- Decrease
b- remain unchanged
d- increase
a-bs 88-2
b-bs 3036
c- bs 1362
d- bs en 60898
The last one is correct.
- - - Updated - - -
You don't take a Zs at just the origin or just the last point on a circuit.
Where do you take it from then?
Reply to Exam question help in the UK Electrical Forum area at ElectriciansForums.net
If you are unsure do both.
Yes I think back in the dark old days they were called deeds but are now called contracts and some still refer to it as deeds like I did! Sounds...
