View the thread, titled "Excellent Wiring !!!!" which is posted in UK Electrical Forum on Electricians Forums.
Hi
Took this picture of some new wiring in my nieces house ( 1930s build ) done by a qualified electrcian , allegedly ! .
It is located on the underside of the 1st floor floorboards .
Spike
Existing Notches maybe.
And was the Sparky aware of the ceiling being boarded, maybe he / she wanted to keep the cable well out of the way.
Not sure if they new that or not , but in my opinion it is not accepted to have cable running under and attached to the floor boards , the cable should be clipped to the joist at least 50mm below , I am nearly sure there is a reg mentioning this ! .
If the notches were already exiting then he/she would have used them as drilling the joists would have weakened them. Was the electrician informed that the ceiling would be boxed in?
Is there RCD protection for the circuit? Is the floor above carpeted/laminate/tiled restricting access to put plates in?
It used to be common practice to notch joists rather than drilling them as electric drills were extremely rare and bit and brace would be very difficult to get in there.
No , the notches were put in at the time of this install , they lifted the boards in the lounge above .
Reply to the thread, titled "Excellent Wiring !!!!" which is posted in UK Electrical Forum on Electricians Forums.
