View the thread, titled "Extension" which is posted in DIY Electrical Advice on Electricians Forums.
Re: how not to wire your extension
hi o/poster i,m a sparky (since 1968) 60 now
ive been reading this thread on and off
its gone sidways in part hasnt it?
the build looks really good
the plumbing and elecrtics no good
I must confess my original intention after having stumbled across the website from elsewhere was a bit of p*ss taking and ridicule.
But once jonwade appeared as the customer on the receiving end of the work my intentions did change to being somewhat more helpful.
The thing is 6months down the line it may have been fine, or it may not have been nobody can predict it really.
You could have ended up like the house I was working at yesterday, a forest of dehumidifers and a machine which basically blows hot air into the insulation layer under the screed to try and drive out the water which has collected under there! As far as I know a couple of compression fittings on the pipework buried in the screed had leaked and filled the insulation layer up with water, enough that it travelled through to next door (semi-detached house)
the plumbing and electrics no good
Thanks. I am indeed happy with the building, the windows, the roof, the flooring. I watched all the major bits done and was present when the building inspector came round too. So I am still having the builders complete the work (once the plumbing is sorted) and do the internal work (2 new walls, new window and install kitchen) but getting the electrics and plumbing all done separately.
I did have the electrics reviewed by a local firm who said that it was passable, and should not cause problems, and if it did it is on the RCA and easy to replace the cables. So although I am not happy with how the wires are as such, that is how they are staying. But if I had a good friend who was a sparky I'd probably get them to change it while the builders are away too - but I only know a plumber!
"Passable" "should not cause problems" what would you say if a mechanic said that about your brakes?
Speedfit work on friction so unless pipe is squeeky clean it wont work.
Imho always glue pipe if you have to use speedfit
It was just the otherday i ended up taping up a hose to an outside tap because speedfit is rubbish.
When i was at college doing 2330 we did a little plumbing and at least 1/10 failed.
Cant beat a bit of soldering (doesnt help people don't always use the right inserts. It was news to me last week there is different sized inserts for 15mm pipe
Or cut the pipe square!!
show me a man who can wipe a lead joint and you've got a plumber. otherwise just a pipe monkey/jointer..
It does'nt work on friction there are little metal blades that act like barbs, when you push the collar in they release the pipe, the problem comes from the pipe itself getting scratches in it when dragged across the floor or pulled in. Then when the fitting is put on it weeps past the seals vier the scrathes, its the same with hep2o, the only difference in inserts are between hep and speedfit, you have to use hep inserts on hep pipe and the same for speedfit, to my knowledge you should never use glue
As everyone has said its a p**s poor job all round but as i suspect the electrics in this extention have been taken from existing circuit and so are not notifiable under Part P which proves Part P does not work in it present state. If any Part P reg spark signs that off, which still is not completly clear if this is allowed yet , they need to be reported.
I only use the push fit stop ends have never used anything else speed fit for pressurised pipes I have use push fit poly pipe waste fittings which are good and ways to use
dubbo why do you bother repling to the idiots on here most are totally clueless
i guess ill be chucked off again by
I've never seen him repl to any of us.
Sometimes you worry me Ayjay :)
Reply to the thread, titled "Extension" which is posted in DIY Electrical Advice on Electricians Forums.
