OP
Geordie Spark
Re: how not to wire your extension
When I was working, I was sparking, plumbing gas fitting and doing wet central heating work.
I used Speedfit when it was new to the marked and was sceptical about it so when I first used it to install a heating system in an upstairs flat I air tested the installation to 3Bar & left it overnight.
Next day I water tested to I (think) 4 Bar for the whole day.
When the job was completed, I handed it over to the customer fully working running at 1.5 Bar.
It was almost a week later when I took his phone call telling me that during the night there had been a masive leak and it had brought-down the ceiling in the flat below.
Investigations showed a 22 x 15 x 22 tee had failed catastrophically.
Speedfit offered to replace the fitting Free of Charge.
I have been very wary of ALL plastic pipe and push fit fittings ever since.
I have such a headache - stress.
Whenever I mention the fitting they say "this is the way we always do it, push fit has been used for 15 years now no problems".
I have printed out the speedfit info on installing in ground and selotaped it to the radiator. Will insist that it is done as set out by Speedfit.
