Fault on socket circuit | Page 5 | on ElectriciansForums
Discuss Fault on socket circuit in the UK Electrical Forum area at ElectriciansForums.net
G
Grant McLaren
I am puzzling over an intermittent fault on a ground floor/kitchen socket circuit. Initially it seemed as soon as the oven switched on the RCD would trip. However, after unplugging the oven, I used a socket tester on other sockets, which would sometimes trip the RCD. It's pretty random, sometimes it will trip as soon as you plug something in, other times not. Zs reading were fine. The ring main has been broken, although the earths are still continuous. From what I saw, the socket circuit has not been done well.
When I left the property yesterday everything was on, but I'm waiting for a call from tenant to say it's tripped again.
Any thoughts on what it could be and why it has suddenly started now?
Regards.
So just like this post your using guess work to carry out jobs. You are a chancer who has no idea what you are doing.
Please tell me Dillb, how is it that by downgrading a 32amp to 20amp is a bad thing or bad practice. Please explain the logic. Surely, it is more risky to follow your practice and assume, because the RFC is continuous that some cowboy hasn't come along and spur off the ring with no protection.
Well I was just wondering Spoon, if Grant has, either given Money to the NICEIC (Thanks for that Dillb) or he is registered, begs some questions how on Earth (judging by some of Grants statement) was this acheived? and was the assessment carried out in the Assessors Vehicle.
Becasue thats what testing is for.
You do know how to calculate R1+R2 for a RFC to ensure there are no spurs on it dont you?
If it's just 1 socket being spurred off of a RFC what protection would be required?
I know this.... I know this.....
[ElectriciansForums.net] Fault on socket circuit
Reply to Fault on socket circuit in the UK Electrical Forum area at ElectriciansForums.net
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
I misread it.
