Fault on socket circuit | Page 4 | on ElectriciansForums
Discuss Fault on socket circuit in the UK Electrical Forum area at ElectriciansForums.net
G
Grant McLaren
I am puzzling over an intermittent fault on a ground floor/kitchen socket circuit. Initially it seemed as soon as the oven switched on the RCD would trip. However, after unplugging the oven, I used a socket tester on other sockets, which would sometimes trip the RCD. It's pretty random, sometimes it will trip as soon as you plug something in, other times not. Zs reading were fine. The ring main has been broken, although the earths are still continuous. From what I saw, the socket circuit has not been done well.
When I left the property yesterday everything was on, but I'm waiting for a call from tenant to say it's tripped again.
Any thoughts on what it could be and why it has suddenly started now?
Regards.
Hang on you mentioned existing circuits. Not new ones.
yes, if I do work on an existing circuit, which requires minor works or domestic installation certificate, I will usually (not always) assume the ring is broken and downgrade. If I come to a kitchen circuit, I might do it differently and keep the 32 if the ring is continuous. But this generally speaking, not a hard and fast rule.
So you could actually be charging your customers unecessary money for materials npt needed? Rather that. Carrying a few simple tests to prove everything is fine?
Whats a "domestic installation certificate"?
what in the ruddy hell is going on here
[ElectriciansForums.net] Fault on socket circuit
Why is it funny? Why wouldn't you do it?
Why would you 'assume' the ring is broke. Why not test it and fix it if it is.... Rather than ripping off the customer and charging them for something that they don't need...
Maybe the NICEIC have designed themselves a new cert...
Well I was just wondering Spoon, if Grant has, either given Money to the NICEIC (Thanks for that Dillb) or he is registered, begs some questions how on Earth (judging by some of Grants statement) was this acheived? and was the assessment carried out in the Assessors Vehicle.
Reply to Fault on socket circuit in the UK Electrical Forum area at ElectriciansForums.net
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
I misread it.
