Faulty light, do I charge customer to replace | on ElectriciansForums
Discuss Faulty light, do I charge customer to replace in the UK Electrical Forum area at ElectriciansForums.net
H
Happygrumpysparks
Hi,
I installed a security light 8mths ago, customer has informed me the light is only partially working.
Customer wants a replacement or upgrade and he will pay cost of upgraded fitting.
Where do I stand with this regards it being a manufactures Defect and not a fault of my installation. Do I charge labour or not?
part should be fit for purpose and should last. I would speak to your supplier and try and bill them for your labour. defo not the customer. its hardly there fault and a bit of good will goes a long way.
This is always a tricky area. 8 months is poor, but I don't think you will get any joy from the supplier other then replacing the original fitting. I try to get the customer to supply the light if at all possible, but if not I use a supplier that I know will not argue the ----, TLC are brilliant for that. I think you are quite justified in at least "going halves" with the customer if you explain the costs and so on. I don't think it is fair to expect us to just come and swap it out for nothing. If he is just covering the higher cost of the fitting you are still on a loser. If it was a regular good customer I would probably just swallow it but not if it was someone that I will never see again.
I disagree sparksburnout....Your markup should cover your guarantee. I always try to avoid customers who want to supply their own stuff....I view these people with deep suspicion ha ha .....I suppose in the great ecosystem that means our target customers do not overlap lol.
Seriously though if your markup does not cover you returning to the odd job now and again the there is a problem which is either 1. Your markup is not enough or 2. Your supplier is supplying you with tat.
Or 3. my customers are tighter than yours.
If you supplied then do free of charge if the customer supplied then apply a labour charge.
I put this on my written quote estimate before I do the job that way when they use cheap and nasty fittings you know will fail in a short period of time you can say smugly I told you so!
I would play by ear if it is around the corner and a like for like change then probably no charge as a good will gesture, all depending on how much work involved.
Exactly. If its a regular customer or just round the corner then yeah fine. If it's some tight *** who has tried to squeeze the last two quid out of the price then........
Could well be the case mate lol. Although mines are tighter than yours when it comes to replacing installed items supplied by me lol. Im not knocking you mate ...not at all you follow the business model that works for you. I wonder what the split is of people in general ie those who supply the customers with parts and labour and guarantee all and the model you and others run by which is basically a limited guarantee.
TBH i took a decision a while ago to try and insist that customers get their own light fittings, internal and external. It does have the downside that you end up with some carp to try and fit (well known Swedish stuff for example), but if its too bad i just tell them its not fit for purpose. On the up side though, you have no headaches when it fails, and if they insist on going cheap and cheerful then they just pay twice to have it installed on top of the hassle of getting it replaced. If they are struggling then I just provide them with a link for the particular item, for example LED floods. I used to get cheesed off spending hours choosing a particular item and then Mrs customer says "ohhh is a bit bigger than I had expected"
i'd relpace FOC within the 12 months. though if it was 30 miles away i's ask customer to wait till i had other work in the area, as long as the job was not urgent.
OK,
Firstly, thank you for everyone's input.
The customer supplied the light, the light is under warranty and he is arranging its replacement.
Ive taken on board what has been said. I'm going to pop back and change out for the replacement at no cost. It's not far from me and for the sake of 30minutes gives a good reflection on my service
Ive learned a lesson, some items I purchase online which I'll no longer do. Mainly as I need the locality if returning to a wholesaler if anything goes faulty.
Reply to Faulty light, do I charge customer to replace in the UK Electrical Forum area at ElectriciansForums.net
Met landlord on site as he lives not far away and showed him which filters he needed so he could see for himself. Cooker is on inside wall of a...
Depending on the specific battery you (intend to) buy, you might be able to just do Monster alternator -> LiFePo4 battery. The BMS for the fancy...
