Can you use ferrule crimps on 230v such as power and lighting if you use stranded cables ?
Discuss Ferrule Crimps in the UK Electrical Forum area at ElectriciansForums.net
Amazon
Can you post a link?
800 PCS Ferrules kit, VFENG Wire Ferrules Crimp Connector, Insulated Cord Pin End Terminal AWG 22-10 Kit,Great Assortment Ferrules Kit with Case: Amazon.co.uk: Amazon.co.uk:
Shop 800 PCS Ferrules kit, VFENG Wire Ferrules Crimp Connector, Insulated Cord Pin End Terminal AWG 22-10 Kit, Great Assortment Ferrules Kit with Case. Free delivery on eligible orders of ÂŁ20 or more.www.amazon.co.uk
The 16A you are referring to is AWG or American wire gauge.
Took me a while to find where you were getting 14A and 16A from
So these are not the amp ratings. I cant find any amp ratings for them at all.Green = 100pcs Wire Range: 24A.W.G, 0.3mm2
Red = 100pcs Wire Range: 22A.W.G, 0.5mm2
Blue = 100pcs Wire Range: 20A.W.G, 0.75mm2
White = 100pcs Wire Range: 18A.W.G, 1.0mm2
Black = 100pcs Wire Range: 16A.W.G, 1.5mm2
Gray = 100pcs Wire Range: 14A.W.G, 2.5mm2
Orange = 100pcs Wire Range: 12A.W.G, 4.0mm2
Green = 100pcs Wire Range: 10A.W.G, 6.0mm2
tIf you look at a reputable supplier such as Weidmuller you will see that their crimps are rated at the same current carrying capacity as the cable they are fitted to.
a properly crimped bootlace ferrule, surrounds the cable and increases it’s csa slightly at the point of termination this reduces hot spots at the point of termination.
you'll wonder where the yellow went, when you brush your teeth with pepsodent.Green = 100pcs Wire Range: 24A.W.G, 0.3mm2
Reply to Ferrule Crimps in the UK Electrical Forum area at ElectriciansForums.net
