M
MikeGT729
Hi
Firstly I don't have any electrical qualifications, but I am undertaking an installation which will be certified by the local council, however I have to get it to first fix before they will come out, so want to ensure I get it right first time.
Installation is in a utility building, with its own mini consumer unit, 63a main fuse, with a 32a and 6a breakers (if I remember right, I'll update this if I've remembered wrong). I've already installed all of the conduit, 20mm pvc. Wanting to use conduit cable, as T+E would be too tight of a squeeze in places.
Load will be minimal, going for 1.5mm for lighting (LED), however not sure what to use for main wire in from house and for the sockets circuit. Fuse where I'll be connecting to in the house consumer unit is 32a.
2 main loads on circuits will be tumble dryer and an electric heater, both around 2kw. Also considering a solar battery storage at some point in future if that impacts. What size cable would be required?
To summarize, need to know
Cable size for house to mini consumer unit
Cable size for sockets circuit.
Let me know if you need more info.
Much appreciated in advance
Mike
Mike
