Always makes me cringe when you hear what the call out charges are for these big companies especially when you get somebody on site who damages a cable or dislodges a detection device and gets stung with a rediculous bill
Quoted against some of the big companies on intruder alarms in the past and some of them appeared to be quoting at cost or less for the system at times but they certainly made it back on maintenance and call outs within a very short time
Nature of the game.
To you and me, a £200 call out charge is ridiculous.
I always found it hard to justify why a detector and base that cost one of the Big Blues around £8 was charged out at well over a hundred and fifty.
Ultimately, it comes down to covering the overheads, paying the wages, and........returning the shareholder's investment.
The whole "open and closed protocol" thing is a bit of a misnomer - a protocol is the language used to communicate between the devices and the control panel.No matter which manufacturer you use you are tied into using their protocol.
The issue really is that some of the big companies are mercenary when it comes to maintenence costs and the reason behind this is that they have went in negative/zero profit to win the job and look to recoup through maintenance,which is a stupid way to do business as no one is tied to any one company in relation to the requirements of section 45 of 5839.
That is the same as in the case of your car (and,as pointed out,was the reason for the change in the car companies warranty policy) - you can take your car to any garage to do an oil/filter/brake change etc.If the ECU pcks up on it then you either (i) go to your local backstreet garage who has "contacts and get it done there or (ii) you take it to the main dealer to get it fixed - I know where I go with mine.
As an engineer,I have a lot of respect for Apollo and Hochiki as they are both established and reliable products but they do end up getting connected to some of the biggest buckets of rubbish out there by contractors who think it's real handy that you just have to autolearn and run,withot actually knowing what they are doing.
Pricewise,our detectors cost price is little more than an Apollo Discovery and it's a similar story across the board.
Not sure I really understand your argument here, to be honest.
It is common terminology within the fire industry to refer to open and closed protocols - and does not ignore the "meaning" of the terms protocol.
I should imagine there are few within the industry, or around it, who do not understand the differences implied by the terms - i.e. that an open protocol system (referring to the fact that the control panel is capable of supporting a design based on any one of a number of "open" or non licenced protocols, is different than a closed protocol system - generally containing a control panel capable only of communicating with a specific manufacturer's devices, under licence.
In simple terms, if you purchase say a Gent control panel, you are utterly restricted to using Gent field devices, unless you connect every device through an interface. Hardly practical or cost effective.
Yet, if you purchase an Advanced panel, or a Morley panel, as a designer, you have flexibility to choose from a number of protocols, often even after purchase of the panel, and can select same based on design requirements, functionality, and other considerations too.
Even long after installation, for the change of loop driver cards, or a simple software change, control panels will be able to utilise any other of the "open" protocols.
The term refers entirely to the licence, and use of the protocol, and is therefore accurate.
Apollo, Hochiki, Nittan - key among the "open" protocol players, don't ever suggest a particular control panel for use with their detection protocol and devices - just as no open protocol panel manufacturer especially recommends use of one protocol over another.
Again, that's simply the easy view.
I wonder what your maintenance charges and fees might look like if you employed over 8000 staff, ran several buildings, vehicle fleets, and maintained overheads such as theirs.
The primary motivation behind their charges is simply to make a profit, the same as each of us here who run their own business. The perception that they are mercenary exists only because their business model allows them the flexibility to offset loss in one department against a gain in another. Overall, many of their margins are broadly the same as for a smaller business, but just spread out differently.
Nor do most protocol manufacturers care who carries out maintenance on their systems, though they recommend, as we all do, that it be completed by a competent person, they generally only want to get involved where additional commissioning is required, for example - and they do this to protect their business model - licencing of the protocol they have developed, presumably at great cost, which needs recouping.
It is easy not to see the value of a closed protocol system over an open, until you get faced with a very large system, with specific configuration requirements, which cannot easily be achieved by those offering a broad purpose, open protocol for wider consumption.
That's really the point of the openness of their protocols - and like anything, when their devices are used properly, they frequently outperform some of the closed protocol systems available.
The fact that they get "connected" to some of what you term "biggest buckets of rubbish" - is testament to the fact that open protocol systems are widely used, and work as well as specific closed protocols.
The protocols developed by Hochiki and Apollo cannot be held responsible in any way for the design of the installation, however. And indeed, they are protocol developers, as much as field device manufacturers.
Ah. A sales pitch, perhaps?
Which detectors are your detectors, specifically, pray?
Some intersting points there Bill.
The issue I have is the use of the word protocol in general in relation to whether a system can be worked on by anyone or just approved/licenced contractors - you're still stuck with using the same protocol,whether it be Apollo,System Sensor,Honeywell/Gent or TYCO.Yes,you have the option to change all your field devices from Hochiki to Apollo and either select from a different control panel or upgrde the loop cards but thats as close to having to rip out an MX2 and all it's field devices as you can get.Don't get me wrong,I will design a system using Advanced with Apollo for certain sites that don't need the whole package of C&E that we can provide but you'll not see me throwing in a Quadnet ever!
As far as high overheads etc. goes,the company I work for is a multinational so yes,our hourly rates are higher than the one man and his dog operation but even he is getting it tough when PAT testing companies are pricing for fire alarm maintenance with no training. I am also aware that within the bigger organisations that they try to tie the customer in to maintenance and who wouldn't - a lot of people don't like to say it but if it's done right it is the proverbial money for rope (and,by done right,I mean the maintenance visit is done right,not the selling of the contract) and gives returning revenue.
As far as my comments go on pricing,it wasn't meant as a marketing ploy but just a statement of fact and for that reason I won't be naming our product or company.We are currently developing a scheme were the customer gets the software specific for their own site so that they can go elsewhere but they will be 110% to blame if Mr "Numpty with laptop" gets at it without training and mucks it up.
Ideally,no one should have an issue if the software is available to those who are proficient and competent in using it but there has to be a return on the R & D work put in by total system providers,rather than componant manufacturers.
I'm not aware of anywhere, or anyone, where "open" protocol has been taken to mean you can use a device from any manufacturer at any time, irrespective of what's already on the (analogue) system. I guess that's what you're saying "open" protocol should mean?
I know there's a generality in the industry as to referring to the "system" as open or closed protocol, but that's effectively the case, depending upon which comms protocol has been selected by the designer. The point is, and is well understood by the industry I think, that an "open protocol" system will generally be maintainable by anyone with access to fire industry suppliers.
I sort of get your point, I think - though I'm not sure how you'd refer to a system using a closed protocol over an open one, or vice versa if not by defining the nature of the protocol in use.
The real issue is in the licencing - it would remain far cheaper to rip out an XP95 installation and replace it wholesale with Hochiki or Nittan stuff than to remove a closed protocol installation and replace it. Each protocol available has advantages and disadvantages. The balance is really in the cost of maintaining the system over time in the end - cost of ownership.
As previously said, for most of us, there are clear identifiers at design as to whether an open, or "general licence" protocol, or a closed or "limited licence" protocol will achieve the required results better.
Ah, for that ideal world. Multinational, and doing it right don't often go hand in hand when it comes to maintenance - and trust me, having run a service department for the other big blue one for a number of years, I know. And I disagreed. And I run my own business these days.
Taking the case of large company maintenance and doing it better - when engineers are effectively turned into sales men, and targeted on a revenue stream, it's never, ever, going to make for properly carried out maintenance - it will make for a nice, shiny installation with no component older than the last service visit, though.
Equally, I take your point 100% about operations moving from PAT testing into fire maintenance with no qualifications or training - we all see examples of that time and again. And sadly, to me, it's often a very similar mentality to that the larger nationals have been guilty of many times - drive service quality down to maximise return on revenue. Very many of these outfits employ, or indeed, are ex "big blue" lads from both camps, some of which never got the chance to find out how to service a fire installation properly.
Interestingly - of that service department I took over, only one out of 37 engineers had a calibrated meter. Eleven of them didn't have a meter at all, yet were able to replace faulty batteries based on current readings taken by, I guess, necromancy of some type.
Okay - your initial post (you said "our detectors") seemed like you were working for a manufacturer - this one make it clearer that it's one of the big blue ones (I guess the one with an A) - and indeed, Minerva stuff at cost isn't really any more expensive than Discovery - its the costs that come down the line - again, cost of ownership long term.
I'm not adverse to paying for the "right" to work on a specific protocol - and indeed, we have discussions in place with two or three just now, with a view to full and proper access to the protocol and commissioning of devices, support, etc. Against that, most of that is something I get for nothing from Apollo, Hochiki and Nittan - the three primary protocols we use these days. Okay, I do pay for it in terms of detector cost, limitations of technology, and I guess in the insecurity of losing contracts at renewal - to anyone else with access to a general trade supplier.
Taking Minerva as a case in point - if I had a business need for it, then I'd happily pay a royalty to ADT/Tyco for the training and use of the protocol. It is purely the differences in business model - closed protocols will generally not recoup development costs due to lower volume of sales, whereas the "open" protocol manufacturers have opted for volume of sales to recover development cost.
And sadly, I think Mr Numpty with Laptop is also a feature that will always be with us - both numpties and laptops are cheap these days. They'll screw up an Advanced MX4000 running Apollo as easily as a Minerva MX2 with full, intricate C&E covering every device on the installation .
I agree totally, with you, however, that rights to work on a protocol developed under a limited licence (and hence controlled), should be released only to those with full understanding and training - and indeed that said software should be released the the controlling company to the maintaining one, not the customer, and only on proof of training, agreement to maintain that site, and ongoing development training as the protocol further develops and advances.
That's pretty well the Gent 24 program works, the Autronica one used to, Coopers Menvier does, and so on.
I think we managed to come on board on most aspects of that then Bill (and I think the rest are just personal opinions!) - although I'm not ADT (although have been previously for my sins).
We sel the most detectors worldwide if that helps and all our gear is our own (if that helps you any) - I also know that people have nightmare stories about us as the rest but that seems to be a mainland GB thing!!
Nightmare stories are a British thing in most industries lol - and I'm sure I can share an ADT story or two too!
So, I'm thinking that if you are manufacturer based, it's probably System Sensor?
Although, Apollo claim to be the largest "independent", I'm sure you'd not have compared your detectors to Discovery, if you were Apollo.
These so called 'specialist' companies are akin to a yakuza protection racket IMO, just the other day infact I was quoted £360 for a half day commisioning visit on one of these 'closed protocol' systems but I had to pay it, there were no other options.
There's companies that specialize in fire alarms but they aren't all necessarily "closed shop" and then there's companies who see fire as no more than a distribution board with sockets on either a ring or radial circuit - these are reason enough to have some sort of management on who can work on them.
£360 for a half day including travel to site is what it is, the rate for an engineer in half day units.
Again good points, lets just clear up the word Protocol. Yes of this is the command language used to communicate with detection, but must run with the control panels software. I supposed it might be a good idea to call the said panels "open/closed systems" Good example of this is Notifier, a closed system but actually uses renamed system sensor protocol. I think the other problem here is when fire alarm companies are not given any chance to train of apply for some closed systems. And these systems can only be commissioned by the said manufacture at great exspense. This was my original tread stating elctricians are being held to ranson by the said companies, when the have purchased the system from wholesallers.
Siemens Bill.
Who commissions it then? I've seen cowboys buy a fire alarm in a box, autolearnt the system and walked away with no text strings or zones programmed,never mind no isloators out in the field!
I think we`ve all seen that situation, Most electrical wholesellers are using Cooper-menvier which electricians are installing then waiting a few months and a lot of money for a commisioning engineer to turn up. The biggest problem here now is the design.
Rediculous IMO....£360 for 3 hours worth of plugging in a flamin laptop!
Fire Alarm Open/Close protocol
Security Alarms, Door Entry and CCTV (Public)
tazz,
Engineer54,
