Fire alarm panel | Page 2 | on ElectriciansForums
Discuss Fire alarm panel in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Were here to help not to judge....C-Tec are a great up an coming company, and no problems with there panels, alarmsense is an expensive way of installing, so let put this down to cost for you, Apollo alrmsense sounder/base/smoke about £38...
Apollo S65 £8 Apollo sav base £5 squanshini base sounder £10 so £23 total per point, alarmsense call point £15 standard call point £4...on average you have the same system for £200 or so less.
Not a problem Stranded with kentec or other 2 wire systems like Haes, you can install what you feel is best like apollo S65 , hochiki, Orbis it is the sav base which is the key, and any normal sounder is compatible....so we have a veryflexable system
Its a simple system.....when the alarm is activated , the polarity changes....hence polarised sirens which are standard from all manufactures.
Reply to Fire alarm panel in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
