fire alarm | Page 5 | on ElectriciansForums
Discuss fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thats the panel as you have already worked out, once changed will work with ziton detectors....is other issue is the age of the detection, it looks over 10 years, so would suggest changing.
When you put the key in the MCP, did you leave it in there for a few seconds? Newer panels will activate immediately but older ones which work on a short circuit can take up to 3 seconds to operate. Some even more although it should be less than 3.
Another we question , how come there was no eol resistors in this system , I did see call points had 1 built in , and you just snipped, but wasn't end of line
Reply to fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
What was the make and model by the way?! What type of fire alarm too, most addressable systems you can simply add a relay output module to the...
