First electric shock | on ElectriciansForums
Discuss First electric shock in the UK Electrical Forum area at ElectriciansForums.net
everywhere
Some of the regulars will know I'm in training...slightly confused...all day today I've been sleeving the cpc because none at all had any on and putting connector blocks in choc blocks..15mins before leaving I have my head above the ceiling...power on since where we are working are open and they don't want a third of the store in darkness from killing the mcb.
Had the connector block between finger and thumb..carefully putting it the choc block when I heard it cracking..was tightening the screws when I got a belt.
So I'm thinking could it arc...I didn't see anything...just felt it.....or Is it more likely I just had a brain fart and my thumb touched some exposed conductor?
I
Least I know the rcd kicks in fast
Are you perhaps typing with the arm that got the belt ? Lots of gibberish going on there. From what I gather though you were working on exposed live conductors. No sympathy from me there you absolute idiot !
If it was your choice as a trainee to work live then you deserve the shock, and a slap. If it was the guy who was supervising you who told you to work live, then you both deserve a slap.
There are times when it is appropriate to work live when circumstances prevent isolation. This does not sound like one of them.
I was told holding the connector is safe...the store won't have power off
Am I supposed to refuse to work then when the main guy says hold the connector block....genuine question
Put it this way I'm only half way through the ground floor..rest tomorrow..then first floor and I'll brr babing it holding my first connector block tomorrow
No need to be "babbing it", that's what safe isolation is for, to give you confidence you are working on a de-energised circuit.
Take this shock as a learning experience. If you don't learn from it then you probably deserve another shock. Get your AVI on anything you disconnect. Even if a circuit is isolated, you never know what you are getting hold of, especially above a suspended ceiling.
Am I supposed to refuse to work then when then main guy says hold the connector block....genuine question
Yes ! unless you like putting your life on the line. Your Boss is breaking the EAWR and health and safety laws by asking you to work live when it is not necessary to do so.
Reply to First electric shock in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
