Fitting new consumer board - no part p?
So you pull the fuse, rip the board out, and wonder why those VIR's are crumbling before your eyes.
And that's just the beginning !!
Look before you jump, that's the Grand Canyon looming before you.
I had an email yesterday, Stroma are giving it to members for free. I get the feeling Building Control can't be arsed with Part P now and this third party certification will stop them getting asked to arrange contractors.
So for £288 all in you get the Third party certification thrown in as well ?
Realistically you should never consider doing a consumer unit change without carrying out some basic tests , whats the cable is it PVC or the good old VIR , what about bonding to services water gas oil etc these i name a few and as beens mentioned insurance
Building Control can't be arsed.
Yes that's very true.
The fees they charge for the exact same service varies from council to council.
The councils that really can't be with BC demonstrate this by charging a much higher fee.
get yourself a tester mate, no need for £500 new shiny one, second hand machine doing insulation resistance and continuity will do, every electrician should have one and know how to use it...
We'll it'll get tested after it's been installed so why should that be a problem? Seems a lot of money to get registered if I'm not doing it as a business. Work full time as maintenance in a factory thanks for the replys
tomodo, leave it alone, no test gear how can you do it, never ever change a CU without testing the entire installation before you rip the old CU out, you are installing a CU wit RCDs in it, just think about that.
No test equipment so that's a no go. Just wondering what the law was?
The law is "The Electricity at Work regulations 1989". This is what you will be prosecuted under if it goes bad. A lot of people think that this law doesn't apply to Domestic Installations, they are wrong, if you are doing stuff in your own house it doesn't because it can't be enforced, but if you do it in someone else's, it does and you will get crucified.
Building Regulation Part P is also the law.
Cheers.............Howard
Sorry, and I mean know disrespect to the OP.
But reading through this thread your simply not ready to approach the task at hand.
Remember,
Being competent has never been about what you know.
Its about knowing what you don't know.
1st stage is to have the whole installation thoroughly tested as per an EICR.
Don't need to complete the whole form if factored into your price but you need to visually check the installation and record readings for your benefit.
Once you have identified any dangers or non compliant problems you can tackle the job issuing an installation cert after completion.
Part P registration is as much, if not more, for your friends benefit.
You need an established qualified sparky at your side and run through the job with him.
That's my honest opinion, and advice. :icon12:
tomodo,
richy3333,
