Fixing backbox to aircrete / thermalite | on ElectriciansForums
Discuss Fixing backbox to aircrete / thermalite in the UK Electrical Forum area at ElectriciansForums.net
Deleted member 112675
Hello All
When fixing a backbox to soft airated blocks like aircrete etc, do you use special fixings or is a pair of normal brown plugs typically good enough ?
Thanks in advance.
1.5 x 10 screws into the correct plugs - solid as a rock
[ElectriciansForums.net] Fixing backbox to aircrete / thermalite
Hello All
Thanks in advance.
Dampen the hole you have cut for the box:
Drill some fixing holes:
plug and add some long fixing screws:
Whack in some Compo (BRICKIES MUCK) remove long screws. set box in said Compo reset some screws, make sure box is level , fill in the rest of the hole with Compo, wait until Compo has set tighten screws and Bob's yer Uncle, or in this case box fitted.
I used to use no.8 1 1/2" screws with red plugs.... for years... then I watched another spark plowing screws straight into the blocks with no plug.... that's rough I thought.... but having tried it it holds aswell as plugs! Tends to be rendered in pretty soon after so now that's what I do
Reply to Fixing backbox to aircrete / thermalite in the UK Electrical Forum area at ElectriciansForums.net
N
Help Needed: Fixing My Damaged Tub with Devcon Metal Patch & Fill Hey everyone, I have a pretty messed up tub that I need to fix, and I'm hoping...
NETSURFER802
N
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
    • Friendly
