Flat clamps - Crocodile Clips?? | on ElectriciansForums
Discuss Flat clamps - Crocodile Clips?? in the Electrical Tools and Products area at ElectriciansForums.net
UK
Hi,
I'm trying to source these, person who wants them isn't massively in the know. They suggested 300 odd AMPS (yeah I know). But they need to be 'flat'. Pic included.
[ElectriciansForums.net] Flat clamps - Crocodile Clips??
Look like jump lead clamps.
Have you tried somewhere like Halfords?
(Thanks to your username, my brain is singing “do the Bartman” over and over in my head…. Cheers)
Thanks, they kept saying to me crocodile clips, which they certainly are not. I've tried a few places, plus internet, but no joy. Have contacted a welding supplier on the advice above.
Seeing that welding clamp, it’s uninsulated, and a lot of heavy copper.
The picture in OP still reminds me of a jumper cable. The groove in the centre of the jaw to go over a round pin of a battery.
Ok reread OP, and he does ask for a “flat” alternative.
It might help if we knew what the application was for?
OP, what's the application? Why do they need to be flat contact areas?
I don't think the ops ones are welding, they look like mediocre Chinese jump pack/start battery type ones.
No they aren't welding clamps. But he only showed them as an example of the contact face that he wanted.
Reply to Flat clamps - Crocodile Clips?? in the Electrical Tools and Products area at ElectriciansForums.net
Hi, We would like to have installed new single powerpoints which are on the skirting boards of our old house. However the existing ones we have...
Washing machine drain hose glued!! Hi, Thanks for looking. I am getting a new washing machine who will install, disconnect, recycle it, etc as...
seamybee
There is no specific requirement for a cable to be buried, or at what depth, provided steps are taken to make sure it is not likely to be damaged...
Flange and nuts in the same sentence. Jeez I really must start acting my age.
You can buy the wera ends in singles for replacing broken and worn ends which is nice
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
