Fluke t5-1000 electric shock | on ElectriciansForums
Discuss Fluke t5-1000 electric shock in the UK Electrical Forum area at ElectriciansForums.net
Lincolnshire
Hi, Whilst using my fluke t5-1000 I’ve had an electric shock twice now, I’ve checked the leads and can’t see any damage or wire showing. I’ve stopped using it now but can’t figure out why it happened. Has anyone else experienced anything like this? Cheers Mike
I'm assuming it's not been subjected to moisture or excessive condensation in the van maybe? If not I'd probably open it up and do a visual check of the internals then just relace the leads as a matter of course.
Were you using it as a single probe contact tester? If so is it possible for the other probe to have a higher than expected potential on it? I only ask as I believe some of the other voltage testers behave that way.
You should always either put the neutral probe to neutral first before the L probe, or not touch the neutral probe when the L probe is connected to L.
Reply to Fluke t5-1000 electric shock in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
