following rewire ..... | Page 3 | on ElectriciansForums
Discuss following rewire ..... in the UK Electrical Forum area at ElectriciansForums.net
T
toofar
hello guys looking for your thoughts on the following
fully rewired a 3 bedroom tenement flat installed completely to the 17th edition wiring regulations issued completion certificate (niceic) i was 100% happy and confident on my job
customer tried to withold money as i hadent clipped any cabling for sockets and switches ,
i explained (yes it would be slightley better finish ) but i had already spoken to plasterer and he was comfortable with the job.
basically the customer made it a complete nightmare as if i had left an unsafe dangerous non compliant job
hyne site should have put clips in but jeez
I'd totally disagree with that statement, A 20mm conduit directly entering into the back box is infinitely better than using capping or that crap oval conduit for both rewiring or any future additions/changes. If you need to butcher a wall to sink a 20mm conduit in that wall then your skills need to be addressed. As for light switch positions soon being a thing of the past, i doubt that very much, certainly not for the vast majority of domestic households anyway....
you still need to chase into the brick to get the depth for conduit, though.
Have any of your walls fallen down yet?! :smilielol5:
As I said, it is common practice here (to the point that no-one doesn't do it). But I have seen plenty of walls where you could see through the block because they had gone in that far. So don't try to tell me that it isn't structurally inappropriate, and almost certainly in breach of Building Regulations in many instances!
I like to put 20mm conduit in the walls with an adaptor to connect it to the box. If you use a decent wall chaser, it is very easy to do and looks very professional.
If it's your labours that are butchering the walls, then it's down to YOU to put them straight, ...eg it's YOUR responsibility!! Don't blame the installation/use of 20mm conduit as being a breach of building regulations because it ain't!!
I wouldn't fit any connector fittings to these embedded conduit drops, just let them enter the back box direct. Once you install connectors and bushes you are restricting the internal area and creating cable snag catch points....
LOL. I didn't say installation of conduit was a breach of Building Regulations - just that invariably it often leads to breaches. When working for other firms it is also outside of my remit to choose the labourers!
Also, as Tel says, many walls will not actually enable it to be installed without removing an excessive amount of the wall!
Likewise where I am doing it with PVC I would just run it straight in.
I've never seen a 2'' hollow block, smallest i've seen for many years now is 100mm blocks. So much for the British building regulations. They seem to be going the same way the electrical industry is going, ...Down the pan!! lol!!
these 2" breeze blocks are from the 50's. fitting sockets is a nightmare. i've done a few and had to gob in 2 boxes back to back. customer had then had a few extras.
My parents house was an ex council house, certainly no 2'' hollow blocks in that house, more like engineering bricks and blocks from what i remember. So bloody hard the bolster chisel used to bounce off them!! lol!! There were a few minor walls (basicall build-in cupbords) that used 4'' cinder blocks....
-same here. built in 1955. all walls brick - hard as rock. it was the lower end of the council house market when quantity was more important than quality.
Oh dear, you criticised buildings from the golden era when everything was built using superior materials, techniques and craftsmen. Tut, tut.
There's no need to let facts obscure the view through rose tinted spectacles. The materials used in construction on site constructing anything above a handful of houses was in the main absolute junk. Poor quality concrete, hardly and cement used in the mortar, sea sand used in the mortar and concrete, cinder blocks, honeycomb cardboard walls, chimneys infilled with rubble instead of supporting brickwork, no footings etc etc. No wonder there was conduit everywhere, it was the only thing holding most of the internal walls up!
Still, they were the good old days of craftsmen and quality homes. :rofl:
Don't get me wrong, there was a lot of very good stuff built, the testament to which is the fact that it's still standing now. Equally a lot of the current stuff is rubbish. I just don't subscribed to the 'older is always better' routine. I've seen the guts of too many places, engineers reports etc which proves there has always been rubbish.
It's the same old story, you can have good, or you can have cheap, but you can't have both. Which is what I say to customers if they ask for a reduction on a quote. :D
[ElectriciansForums.net] following rewire .....
Some years ago (mid/late '80s IIRC) I saw the best use of conduit in a domestic setting. We were working on some of the docklands warehouse conversions, and some were done keeping the exposed internal brickwork. All the cabling was put into Galv conduit and it looked the nuts. I have to admit I was sceptical when I was told, but once it was in it looked superb.
The lads that put up the conduit were from Macclesfield I think, somewhere in the Arctic circle anyway. It genuinely was artistry, and not so much as a grip scuff anywhere in sight.
Not exactly relevant to the thread I know, but it reminded me of it. Shame it was in the days before digital cameras and camera phones.
grip scuff?
bit a spit and file is all you need
Reply to following rewire ..... in the UK Electrical Forum area at ElectriciansForums.net
Did he carry out anymore testing so he can fill in the values that are missing on the certificate? Having looked at the certificate again I think...
2 3 4 5 6
14K
Hi Tim, thanks for your input and apologise for not getting back to this thread earlier, COVID!!! As you say it’s not a bad thing at all, the...
4K
No, which is silly, I guess they expect you to use the double pole isolator at the start of the circuit to isolate the fan?
2 3
10K
