Garage consumer unit rcd trips out | Page 10 | on ElectriciansForums
Discuss Garage consumer unit rcd trips out in the Lighting Forum area at ElectriciansForums.net
Do these two lights that are 2 way switched together trip out the RCD with the other lights off?
Yes one of them did .so i swapped it over from one at the front of the garage and the other one to the one at the back of the garage taking them both off this 2 way circuit.
Made no difference it still trips the rcd with the light swapped over.
So my hunch is now they all have live supply going to them regardless of the switch and its the discharge going back to earth from one of them causing the rcd to trip out
Reply to Garage consumer unit rcd trips out in the Lighting Forum area at ElectriciansForums.net
Hope you get better soon .sounds quite serious
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Follow the eic test result page .start with ring continuity including figure of 8.then choose between phase and earth connected together on al...
