Yes
Discuss Garage Conversion Certification Advice in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ah right thanks for clarifying.That was aimed at #12 but your post popped up inbetween. I don't see a grey area at all, complete new circuit or complete rewire of an existing circuit which is no longer existing as it had gone an EIC, alteration to an existing MWC.
What?
Alteration to an existing circuit.If you wire the portion between mcb and say half way but leave the remain half untouched is this new , half new , existing ?
What?
egggackly.my dad's axehas had 3 new heads AN 2 HANDLES, BUT IT'S STILL THE SAME LOG PILE.I fear the answer is back to the triggers broom conundrum
Oh OKSorry
Not sure where this came from , was trying to reply to another question
If you are talking about the dreaded Partpee , then no your job doesn't sound like it falls under 'notification'
It does still however need to comply with current building and wiring regs , but does not need to be scam notified
Reply to Garage Conversion Certification Advice in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
