Garage wiring unsafe and not earthed | on ElectriciansForums
Discuss Garage wiring unsafe and not earthed in the DIY Electrical Advice area at ElectriciansForums.net
caerohilly
I have a two storey garage with supply from house. On closer inspection I saw that the main supply in was not earthed at the junction box and neither was the light switch(feeding three lights), there is also a double socket in the garage not earthed either. I have ripped out all the wiring and junction box and light switch and double socket. I was hoping to rewire it myself, I know how to wire it all up but would like some advice on junction boxes and want to run a fridge and tumble dryer off double socket too. any advice will be welcome, if Im not confident enough I will obviously get a professional in.
As murdoch said, if the house in Tncs, they could have TT'd the Garage, you might have just ripped everything out for nothing.
the main supply in was connected to the junction box by live and neutral, the earth wire in the triple core wasn't connected to anything.
What type of cable is feeding the garage?
Hi mate. Are you saying there were no earth wires to any of the sockets or light fittings in the garage?
Could that be dangerous as the local earth could be at a different potential to N? Or does it depend on the installation being check for that after install?
Were the lights and sockets run in metal conduit?
Hi mate.
Why did you rip out all the fixing, if just the wiring was faulty?
As @Pete999 asked, what type of cable is feeding the garage. Is it twin & earth?
Where does this cable wire to? Your CU?
How does this cable get from its source to the garage?
Does your CU have an RCD?
Reply to Garage wiring unsafe and not earthed in the DIY Electrical Advice area at ElectriciansForums.net
The 3A fuse is there to protect the current lighting. For additional power you connect from the non protected 3A fuse side.
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
