Ge mcbs volex mcbs wylex rcbo | on ElectriciansForums
Discuss Ge mcbs volex mcbs wylex rcbo in the Australia area at ElectriciansForums.net
sunny essex
Hi all
board is 7 years old with no rcd it has Ge breakers in and one breaker has been replaced with a volex mcb.
Question is
i have been told by my local wholesaler that a wylex rcbo will fit in in this board are they corect as i am doing aditions on the bathroom lighting and require rcd protection
thanxs
Richard :)
Hi all
Question is
thanxs
Richard :)
What I have done in the past is to take a spare MCB, say double up the lighting for a couple of hours and blank the spare way and take the MCB into the wholesalers and ask them if they've got any of the same pattern. There are usually only a few different generic device patterns available, they're just branded differently. Then you don't have to rely on your wholesaler for his knowledge!
Reply to Ge mcbs volex mcbs wylex rcbo in the Australia area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
