generators | on ElectriciansForums
Discuss generators in the Electrician Talk | All Countries area at ElectriciansForums.net
R
robbie18
Does anyone have any experience of testing when generators are involved? All ZS readings come out too high for RCBO's that protect the circuits! any help or advice would be greatly received.
not too well up on genny supplies, but assume a TT earthing system, so max. Zs would be 1667 with RCBOs.
Are you sure your earthing arrangement is TN-C-S, ESQCR:2002 prohibits the connection of a PME earthing facility to any metalwork on a boat.
to be honest i am not 100% sure on this. all i find is that when i am looking through my new companies test sheets that all zs readings are too high for RCBO's that are protecting the circuits. Are generators usually TNS earthing arrangement? Cables are run under the water so operating temperatures and everything are hard to determine. Company have the thought that if circuits are protected by RCBO's then they have done enough to which i would like clarification on.
You don't seem to be that clued up on generator supplied systems. So what's the KVA size of this genny, has the neutral been solidly connected to earth, what sort of earthing arrangement does the generator have, single or 3 phase?? A poky sized single earthing rod, isn't going to cut it, on any genny install that's not of the portable variety....
kva sizes are mixed but one we use is 150kva, neutral connected to earth at terminal box,3 phase generator.earth runs from generator on to metal structure of barge. barge sits in the middle of a loch with no earth rods or anything like that. hopefully someone can shed some light on this issue as i am new to generator installs as yous have probably guessed
No earth rods? This gets worse.
So the only earth connection is floating about on the water on the end of a flexible cable.
You really need to step back from this.
obviously there are no earth rods, it is a barge in the middle of a loch. a ship can not have earth rods as it sails so i dont think this is an issue. The problem i am having must purely be down to cable lengths and cable sizes i am sure but my original post was just looking for anyone who has had experience of this environment
what we do is run power to the cages on the fishfarm so by that i mean from cage to cage the cables are under the water. the bottom line seems to be that my new company have been running to small a cable for these installations hence zs values are coming back high
I’m not even sure water bourn generators come under BS7671. Durham is the one to ask. From what I’ve read ships are usually earth free with monitoring systems. I’ve dealt with land based earth free systems and to be honest they were a pain it the butt.
Like Tony, i've no experience of shipbourne generators earthing arrangements!! I think it make some difference whether the barge is floating in sea water or fresh water though. but i wouldn't want to swear on it ..lol!!!
Why not PM Durham Sparky here an ask him for his views on your problem/query!!
Reply to generators in the Electrician Talk | All Countries area at ElectriciansForums.net
We’ve recently completed the first and second fix of a barn conversion that is off grid with solar PV, batteries and a back up generator. This...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
