it's a try it and see. if it fades or is inappropriate, pull it off and start over.
would have been easier to fix/repair/replace the original wireless problem.
Don't take it personally Chris. Good to have someone on board with your sort of knowledge re gas etc.
Remember a sense of humour as well though. I mean that in good faith.
Racist.........white blu-tac?
Hello again ipf,
Another `Wind Up` ?
How could anyone use what You are suggesting to run Alarm cables around the shape of Window frames and Door architraves.
What I keep describing cannot possibly be being constantly misunderstood by the Professional Tradesmen / Tradeswomen on here.
Chris
Wouldn’t it be called white-tac?Racist.........
Non gendered non discriminatory spongy sticky stuff......Wouldn’t it be called white-tac?
Hello DPG,
Thanks for your message.
I do have a good sense of humour but I find it impossible to know whether some Members comments are serious or joking.
Especially when I receive replies which because of what I have described make no sense or are completely inappropriate in terms of actually something that anyone would do or try.
Thanks again for all of your messages.
Chris
a concise description of your brains?Non gendered non discriminatory spongy sticky stuff......
<<<<<< scan of my brain........a concise description of your brains?. you know it#s only banter.lol.
Are you for real?0Hello All,
I am hoping to find a recommendation from members for a small tube of adhesive that is suitable for gluing Burglar Alarm detector cables to UPVC Window frames and Door architraves.
I don`t want to buy a Hot Glue gun and glue sticks as I only have 4 cables to run down quite detailed frames / door architraves.
Plus I have been told that although that type of adhesive does work when running the cables it does not hold them long term ?
I have thought about white Silicone mastic but only if there is no suitable small tube adhesive choice.
I have Googled: `Security cable adhesive` - `Security accessories glue` - Electrical cable adhesive / glue` - but I was finding adhesives which seemed to be designed to be used when jointing cables.
Can Members recommend a suitable adhesive - in a small tube hopefully ?
I am having to hard wire some Window / Door Magnetic contacts to my Home`s existing Alarm system because the Control box has stopped being able to receive the signals from my Wireless Detectors.
Previously the detectors were adhered to the Windows and Doors with strong hook & loop pads and there were only very short pieces of Bell wire running between the Wireless detector and the Magnetic contact on the Window frames / Door architraves.
Thanks in advance for any help / recommendations.
Chris
Never heard of superglue for cablesSuperglue ?
Superglue might not melt the cable, but it might melt the upvc frame and it's quite hard to contain, you risk marking the frames.Hello matt4321,
I have mentioned a few times that I only have 4 x 150mm sections of the Alarm cable to glue to the Window frames and Door architraves - total cable length 600mm.
I have been hoping for a recommendation for a small tube of adhesive - not because of cost but because I would have no further use for something like `Tec7`.
I don`t have any outstanding `DIY jobs` at my home where I could use a mastic gun cartridge size tube of any adhesive.
I am going to buy some Superglue to put onto an offcut of Alarm cable to see whether it will degrade / melt the pvc insulation as that would be very easy to use on the frames / architraves.
I apologise to Members - I should have done that before posting this thread on the Forum.
Chris
I'd just sell the house and move to a better area where an alarm isn't required, tsk peasants.........
I earn my money as a burglar, better money then being an Eleectrikery Wizard..........SWD - I know that You are replying with these ridiculous messages just to irritate me and you have succeeded.
If You really think that people who live in `Better areas` don`t get Burgled you need lessons in realities of life.
There are NO areas of London where `an Alarm is not required`.
Your comments regarding that show that you are very naive about Burglary / Crime - especially as you claim to know various areas of London.
However a person would not have to `know London` to realise that an Alarm system is a good addition to ANY Home`s Security they would just need to have some `common sense`.
People who live in the `Best areas` of London / the UK where Houses cost Millions of pounds usually have much better `Security` than the average Home.
Often stronger external Doors and the best quality locks - perhaps Security grilles on Basement and Ground floor windows - maybe even `Security Glass` in those Windows and Doors - a really good Alarm system and CCTV.
Sometimes even Security Guards regularly patrolling the exterior of the Homes or even `living in`- which I know happens in some parts of Belgravia, Kensington, Knightsbridge etc.
That would be why people who own `the Best Homes` / live in `the Best areas` don`t get Burgled as often as Homes with lesser Security - not because of the area that they live in.
Adding insults to your replies shows immaturity.
Chris
A surprisingly informative link:
adhesive for pvc - Google Search - https://www.google.com/search?client=firefox-b-d&channel=trow&q=adhesive+for+pvc
(Better late than never...)
I will be using the Superglue although holding the cables in place while they adhere might not be easy.
Mitre fast would be ideal in this situation. Comes as a 2 part kit, 1 bottle of superglue and one can of aerosol activator which makes the glue go off within a couple of seconds.
8 pages on how to glue a cable.......... sheeeeeesh ;o)))))))
Me? I never get irritated as I am the most chilled out person who doesn't really give a ---- about most things ;o))))I hope that You are not getting irritated SWD ?
Chris
Hello again Resu,
Thanks for the recommendation / information.
I really appreciate your thoughts on this and I am not trying to contradict you or be awkward but what do you think about this:
I would be concerned that trying to apply a line of Superglue down the cable route [on the UPVC moulding / trim] and then spray it with activator could cause a very messy / undesirable situation before I even got a chance to try sticking the Alarm cable to the activated Superglue ?
Also - would you guess that the overspray from the activator spray would just wipe off the brilliant white UPVC without discolouring it ?
When I attempt gluing the cables onto the UPVC frames / architraves I will have fixed the Magnetic contacts to the bottom of the `mouldings` and the cables will be routed up through the ceilings [following an exactly vertical line] with enough slack to push them onto the adhesive.
After they have adhered to the shape of the frames / architraves I will pull the slack up from above.
I have described that because I would not really be able to apply the Superglue and activator to the Alarm cable and then stick them onto the UPVC frames / architraves as the cables need to be connected first to the Magnetic contacts.
Thanks again - I would be grateful for your thoughts on my questions please.
Chris
back on track, i'd just use a bit of the 12mm x 5mm sticky back mini. trunking. non permanent so can be removed if desired with no melting of the pvc frame which could invalidate any warranty.
I'd go for: line of glue on frame, place cable on top, quick spray with activator. Activator should effectively evaporate but should wipe off no problem if not.
Would be worth a test in a discrete corner if you're worried.
in this situation i would have installed a wireless alarm system, such as the Risco Lightsys (hybrid) or Agility (totally wireless). problem would never arise then.
