View the thread, titled "Gluing alarm cables to UPVC Window frames & Door architraves" which is posted in Security Alarms, Door Entry and CCTV (Public) on Electricians Forums.
thought you did. being as how space is limited down in london town, makes sense. :eek::eek::eek:.
My house is fine for me, not too large not too small at about 100m2 soon to be extended though as another development potential, may need some "fittings" and cables so will PM you with my order so you can rad the wholesalers........ ;o)))))
another alternative is to bead some CIS white compound to the pvc, the stick the cables on. after, then apply another bead over thee cable/s.
This has been going on so long I'm surprised no ones come up with a new invention...….capping and casing, maybe.
Hello again ipf,
Another `Wind Up` ?
How could anyone use what You are suggesting to run Alarm cables around the shape of Window frames and Door architraves.
What I keep describing cannot possibly be being constantly misunderstood by the Professional Tradesmen / Tradeswomen on here.
Chris
Hello again ipf,
Another `Wind Up` ?
What I keep describing cannot possibly be being misunderstood by the Professional Tradesmen / Tradeswomen on here.
Chris
To be fair Chris, without photos it might not be easy for people to picture it. I know you mentioned you were having trouble getting decent photos, but it might help to put them on here.
I don't think ipf is trying to wind you up.
Hello DPG,
Thanks for your messages.
The reason why I think that comments like Members ipf and SWD have been making are very likely to be `wind ups` is how can technically minded Electricians misunderstand my descriptions about UPVC Window frames and Door architraves ?
Irrespective of the fact that there are various moulding shapes / frame profiles made from various pieces of UPVC - different on most windows and doors dependant on the fitter / Window company - I have described that the lowest section is only 8mm thick x 35mm high.
I described that thin lower section because it could not accept a hole drilled to thread the Alarm cable through.
Chris
whatever method you use, to comply with current regs., the cable needs metal fixings to prevent premature sagging. some galv. tray with metal straps would comply even if it looked horrendous. as it's an alarm system, why not upgrade it to a wireless detector alarm like the Risco |Lightsys or Agility? also gives remote access from moby via app.
Hello again telectrix,
Thanks for your message.
The Alarm detector cables are 12 volt so I cannot imagine that they are covered by the Electrical Regulations regarding clipping etc. ?
My Alarm system has been installed for 20 years - I am having to wire up some Door and Window Magnetic contacts because the Alarm Control box RF Receiver has failed and no longer receives the wireless / RF signals from the remaining wireless detectors on my system.
As I mentioned in previous messages I have gradually had to `hard wire` new detectors to the Alarm Control Box to replace the systems wireless detectors as malfunctioned over the years.
When I manage to run the cables around the Window frames and Door architraves and connect the Magnetic contacts my Alarm will finally have been fully changed from the `Wireless Burglar Alarm` that I bought and installed 20 years ago to a `Wired Burglar Alarm`.
Finding a £5.00 or £6.00 [guess] small tube of adhesive suitable for gluing the 150mm sections of the cables around the frame / architrave profiles will obviously be preferable to buying and installing a new Alarm system.
Chris
Or just buy a tube of Tec7 or CT1 or something like someone suggested in about the third post!
Hello matt4321,
I have mentioned a few times that I only have 4 x 150mm sections of the Alarm cable to glue to the Window frames and Door architraves - total cable length 600mm.
I have been hoping for a recommendation for a small tube of adhesive - not because of cost but because I would have no further use for something like `Tec7`.
I don`t have any outstanding `DIY jobs` at my home where I could use a mastic gun cartridge size tube of any adhesive.
I am going to buy some Superglue to put onto an offcut of Alarm cable to see whether it will degrade / melt the pvc insulation as that would be very easy to use on the frames / architraves.
I apologise to Members - I should have done that before posting this thread on the Forum.
Chris
I'm afraid I can only go so far trying to help someone with what is, basically, a minor problem.
For goodness sake, chris, just give something a try....maybe even get some chewing gum and try it as a temporary fixing to see how it looks.
Hello again ipf,
Please see my message to Member matt4321 above.
Chris
Hello All,
Thanks to the Members who have replied to me.
I would be happy for a Moderator to close this thread now if they feel that it has gone far enough ?
Chris
Reply to the thread, titled "Gluing alarm cables to UPVC Window frames & Door architraves" which is posted in Security Alarms, Door Entry and CCTV (Public) on Electricians Forums.
