Hey all,
I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out except one thing. I want the module to stop working if my headlight switch is set to the OFF position, so basically my switch gives negative ground to 1 of the wires when its set to OFF and i wanna use that signal to turn off the module but i cannot figure that out. I can do that with 5 pin relay but that would mean the relay will stay energised and will drain the battery. Does anyone know any other way? Like a transistor or something?
Thanks in advance
Thanks in advance
