Help on an exam question
W
westos-electric
Hi
I need help working this cal. Please can you confirm the answer and how it's worked out?
Question
A conductor 500mm long is placed in at right angles to a magnetic field with a magentic flux density of 0.25 tesla. What is the current required in the conductor to create a force of 15N on the conductor.
Hope you can help
Wayne
Hi ive still had issues with this question
A small heating circuit draws 1.5kw of power and has an internal resistance of 0.5ohms what is the current drawn?
Upvote 0
This is an ohms law question........
Current (I) = square root of, power (P) / resistance (R)
= Sqrt of 1500 / 0.5 = 54.77A.
Upvote 0
I've been reading about transformers and need help on this question
A transformer has an output of 12kva and a power factor of 0.9. the total losses in the transformer are 600w. What is the efficiency of the transformer
now i know / think the formula is output/ output power + losses
I'm not sure how this works out, can anyone help
cheers
Upvote 0
cheers
The formula you require is:
input power = output power + losses
However you need to use:
Efficiency = output power / (output power + losses)
so: Output power = KVA x Power factor
12kva x 0.9 = 10.8kw
Efficiency = 10800 / (10800+600) = 0.947
0.947 x 100 = 94.7% efficient.
Regards
Dichroic
Upvote 0
Electrical Courses
