View the thread, titled "Help please rcd does not trip." which is posted in UK Electrical Forum on Electricians Forums.
A
ashdail
Hi folks I have just installed an new mk consumer unit, but I'm having problem with the 63A rcd's. The test button works fine and it does not trip @ x1/2 it trips at 99.0 @ x1 and fails to trip @ x5 (>40ms) Its not the tester as I've checked it on another installation I know to be good. Any ideas? Help much appreciated.
I have also been surprised by this especially as both incidents happened at the same location...the faulty rcbo is the first I have encountered but the MK rcd is a few years old and in a location which would leave it prone to dampness, dust etc...ideally the board should be an IP56 type enclosure but this would not be easy to achieve...however I do take on board the notion that the tester, once, calibrated may then be used without any further checks on its accuracy, apart from a check box and this would'nt help with the rcd function....?.
Reply to the thread, titled "Help please rcd does not trip." which is posted in UK Electrical Forum on Electricians Forums.
