B
billybee
its not a slate roof its a compisite tile, pined at the front of each tile so they carnt be lifted up.
This thread titled "help please reduced output on hot days" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
Fault list so far in your system;
Hanger bolts ( not recommended for slate)
DC cables not secured
strings wired incorrectly
inverter boxed in
not the best panels
can not see any earth cables on array ( legal requirement with velux windows)
I am sure there many more, I feel you did not choose your installer wisely, I am sorry, but I do not have the answers for you to correct all of this.
the windows should be easily removable, there's a catch on each side, then you can just slot them out.lol it have to be a pritty thin and small lecky to fit through one of those windows lol
there really is only any need to bond them if they are also an extraneous conductive part - ie if there is already conductivity to earth from the frame, which nobody can know for sure unless they're tested, otherwise no bonding is needed.why are they not the best panels and can you show the regs on velux windows earthing arrangement the world has gone mad with bond this bond that.
it looks to me as though you will almost certainly get some shading off the mains cables (with the shrouds off!)
Those look as though they could well be more than 200mm off the roof.
Reply to the thread, titled "help please reduced output on hot days" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
