This thread titled "help please reduced output on hot days" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
now do you believe me?[FONT=&]Bottomline, your inverter is not in the optimized mode,[/FONT] [FONT=&]Assuming you have all panels on same angle and azimuth and no partial shading, you will get a significant improvement of yield having the panels wired as a single string of 12. The key is higher string voltage matching the inverters nominal input equates to max efficiency[/FONT]
afaik you can't actually turn a 2 string system into a single string system via the link cables in the inverter alone.yes thats a simple solution and is it not just the same as these link wires he has sugested, now im not an installer and even though i neebed when the fitted them didnt see everything they did. but to hazard a guess one string is each panel conected to the next till you get to the last one and then them wires to the inverter. now if thats the case im guessing that at the moment and knowing the panels i have that one of my stings is longer (wires) than the other (ones always slightly less than the other (normanal) so if you just joined the two strings with a junction box it wouldnt make much diffrence compaired to linking them inside the inverter. now i'm guessing that by linking where as i have lin1 and lin2 now i will just have lin1 changing the way the system runs.
now going back to what gavin A said, if this linking works and perfromance is up, then the best way forward is to full restring to one that way the DC cable lenth will be a lot less helping perfromance even more. (this is going of several installers telly me the shorter the DC wires the less the looses will be) i'm sure someone on here would no what the diffrence is say between 5 and 10 meters of DC cable.
no. I'm saying that this 3kW installation on 50/50 split on this inverter isn't very suitable, and should only be done if on different roof faces or there was significant shading to one of the strings that the bypass diodes and shading function couldn't sort out well enough.so are you saying Gavin that a 3kw install on a power one split 50/50 is not very suitable ?
Presuming the shading is as minimal as you say, I'd just ask him to wire it into a single string of 12 panels in series.so Gavin do you think it would be worthwhile when the electrician comes to put in the link wires, would it be better for me just asking him to do this possitive to negitive thingy and converting totally to one string straight away. thanks
Reply to the thread, titled "help please reduced output on hot days" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
