Help pricing 3 bed rewire please | Page 3 | on ElectriciansForums
Discuss Help pricing 3 bed rewire please in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hi All - Hope you all had a good Christmas!
I have just recently started my own business and struggle to price work as never had anything to do with that side of things in the past.
Job is to Rewire a 3 bed Detached house
Attic - New radial circuit with 2 sockets. 2 lighting points with 1 two way switch (to first floor landing) - (Attic fully boarded)
1st floor -
3 bedrooms each with 3 new chased twin sockets. Each with 1 lighting point and 1 switch. Main bedroom to have wardrobe lighting point with single switch (chased). 2 bedrooms to have Switched fused spur + install ring camera back entry to external wall.
Bathroom - 1 lighting point 1 switch, 1x 12v outlet (from lighting circuit) 1 extract via 3 pole isolator
Hallway - 1 new wall light with 1 way switch. Landing light with 2 way switch to ground floor. 1 twin socket (chased).
Mid staircase- New twin socket
Ground floor
Hallway - 1 twin socket chased. 4 spot lights. 2 way switching (hallway and living room).
Downstairs bathroom - 1 lighting point (1 switch). 1 extract via 3 pole isolator. 1x 12v shaver socket via lighting circuit.
Shower circuit via DP isolator.
Store room - 2 twin sockets (in stud wall). Lighting point (1 switch)
Living room - 7 twin sockets (chased). 2 lighting points (2 separate switches). Switched fused spur.
Garage - 3 sockets, 2 lights and 3 switch drops (intermediate switching) (sockets and switches in 20mm pvc conduit approx 12m to instal).
New fuse board + Test and certification. (Gas and water 10mm earth bonding already present).
No works in kitchen as is an extension and cable readings were satisfactory.
House completely empty - 1 man and 1 labourer to complete works
Any input feedback would be greatly appreciated ??
I do a drawing if that help
I have read the 10 mins per point on here before, does anyone really think it takes that long, to cut and strip three or even six cables and screw then into a socket or switch, I am interested because I have timed myself and wondered if anyone else has?
Before anyone answers if they don't time themselves, just sit down for ten minutes doing nothing and see how bored you get.
The 10 min thing is probsbly about correct , once you factor in cleaning out the box , cutting & stripping cables , terminating cables , screw back & level , sweep up then pick up stuff and move to the next point.
(not to mention taking a swig of tea and checking Facebook 4 times)
I just made that up - is it actually a thing? Just thinking on average - Considering some points are outside lights, 10mm shower isolator and 5ft fittings to put up..
Ten minutes per point used for pricing means that in a four hour day you can fix twenty four points, but is not a real world fixing time, the only thing that could delay a fixing time to anywhere near that would be a break out cable outlet thats left jagged edges and needs extra work to make the exit smooth. IMO
I’ve never really looked at rewires as a time per point exercise, just as a whole job and rough times to achieve each phase of the job...
mew builds regularly did per point as they tend to be painting by numbers so once you do the first unit you know exactly how long each unit should take
rewires vary dramatically and no two are ever the same
if you are really struggling to get pricing right on day work I tend to say £1250 a weeks Labour and you can’t go too far wrong
Is that to cover you and your apprentice / mate?
So many factors need taking into account on rewires, is it occupied/ unoccupied, decoration, wiring methods.
and whether the nearest pub is within walking distance. ?
Reply to Help pricing 3 bed rewire please in the UK Electrical Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
