Help with new regs regarding mini trunking. | Page 5 | on ElectriciansForums
Guest viewing is limited
Discuss Help with new regs regarding mini trunking. in the UK Electrical Forum area at ElectriciansForums.net
Kyran
Guildford
Hi all
As yet i don’t have the new regs book so I thought i would post my question.
I have a client that manages a block of flats. Its a mid 80s block that has one entrance/exit. As you walk in the font door the clients wants the current lights to come on as walk in. which is fine i was just going to put a directional PIR up over the door as the lights need also to come on when the residents open there doors and walk in to the hall way, which is the other end of the hall way to the front door.
Now in order to get the PIR up over the door I will need to run a cable along the ceiling from the first light that has the permanent live. Normally you would could just put the cable inside some mini trunking. But I know that in the new regs there has been some changes to its allowed use, i.e. as the mini turning melts in a fire the cables drop and there have been case when is hindered firemen. Now what is the permitted way to hold a cable to the ceiling so that in a fire it does not dip down. The distance is only about 2m but it would be right over the door.
Can anyone help tell me whats can be use.
Thank you
Before fancy clips, we had to make our own supports out of steel strapping, to conform to fire regs. Only thing we could come up with....but is passed
[ElectriciansForums.net] Help with new regs regarding mini trunking.
looked at those clips. the scrolling comments say they're self-adhesive WTF? and availability, according to their where to buy page, includes homebase and b&q. FFS.
Those clips look good, but a bit on the expensive side! Not something I will be using.
i think they are about 10p each. I know it can add up a bit if you have a lot to do, but I think you could probably make that back with ease of installation stick sticky back trunking up and screw these up where you would of screwed it up any way.
i think metal p clips are about the same cost and useless in MT.
Reply to Help with new regs regarding mini trunking. in the UK Electrical Forum area at ElectriciansForums.net
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
Sorry to revive a dead thread here but should you not be installing some sort of UPS according to 710.512.1.2 ?
Recommended Sponsor News
Hi everyone,
