help with testing | on ElectriciansForums
Discuss help with testing in the UK Electrical Forum area at ElectriciansForums.net
U
unders13
Hi all
Wondering if anyone can help, I'm just about to do my testing exam at college and not very confident with the full testing procedure, wondering if anyone could wright out or suggest a good way of remembering the full test procedure from start to finish.
Any help would be appreciated.
Thanks unders13
Cripler is a good acronym to remember mate. The test procedure is all there in guidance note 3, grab yourself a copy and read it till you know it inside out. As you read the acronym will make sense to you
numonic? Don't know if that's how you spell it...
From what I remember:
C - Continuity of conductors (dead test)
R - RFC continuity (dead test)
I - Insulation resistance (dead test)
P - Polarity (dead test normally confirmed on continuity tests)
P - Polarity (live test)
P - Prospective fault current (live test)
E - Earth fault loop impedance ZE (live test)
L - Loop impedance test on circuits (live test)
R - RCD tests (live test)
F - Functional testing (live test)
PM me your e-mail address and I can send you a breakdown of all the tests I used when I did the 2391. It's more for when you have to write them out but it will give you a good understanding of each stage. Like the other posts say CRIPPLER is a good to remember.
Hi all
Thanks unders13
Try reading this thread this lists everything you would need to know.
Reply to help with testing in the UK Electrical Forum area at ElectriciansForums.net
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
I don't think it will work with only one stake unless some meters have different operating parameters. It doesn't necessarily have to be a stake...
